jbl 1200.1 hook-up
Correct me if I'm wrong but the JBL 1200.1 has one mono output, correct? Assuming so, 2 8 ohm subs wired in parallel will create a 2 ohm load. Also (again correct me if I'm wrong) 2 DVC subs wired in series would create a 2 ohm load on that amp.
no, 2 8 ohm subs create a 4 ohm load, and 2 dvc subs @ 4 ohms per coil can only be wired at a 4ohm or 1 ohm, and yes that amp is stable at 2 ohms
snapnakk--on the jbl 1200.1
there are two sets of speaker outputs
one is a copy cat of the other for ease
of speaker instlation . you can wire
a 2 ohm sub on each speaker channel
and each sub would get 600 watts( per sub)
for a total of 1200 watts.
Snapnakk
Snapnakk
MN
donaldlovescara
Doxquzme
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
