Louisiana_CRX 5,000+ posts
dem shoes......
So the red and yellow are together to the battery ..and the grounds to the battery ..and each speaker to the Bluetooth amp ?
12v constant (yellow wire) Is connected to 12v battery using a 10-amp fuseMain amp is connected on this set up and is connected to the battery ...
Sent from my Pixel using Tapatalk
On this set up, I didn't wire the speakers.i was only testing for power.So the red and yellow are together to the battery ..and the grounds to the battery ..and each speaker to the Bluetooth amp ?
Orange wire is for backlight on the Bluetooth panel which is mounted on the outside of the cooler.I’m not sure what the orange wire is on the amp ?
Yes and yes but no speakers on this set up. Also Bluetooth amp is the main amp12v constant (yellow wire) Is connected to 12v battery using a 10-amp fuse
---------- Post added at 09:45 PM ---------- Previous post was at 09:44 PM ----------
Exactly! That was my original set up. However same thing happened. Amps powered on for a sec and went off.Looking at the diagram on each amp the rca from Bluetooth main amp goes direct to sub amp ..that’s the only rca connections....the two yellows to battery pos and two hands to battery neg then blue remote wires together..then the two reds from amp and orange wire from main amp to a 12v switch ..can be temporarily hooked to battery ..then hook up highs speakers and subs
It sounds like everything is wired right ...Exactly! That was my original set up. However same thing happened. Amps powered on for a sec and went off.
FYI on this set up I have the 12v ignition not connected to anything. That's where I'm confused. Should that be connected to something?Exactly! That was my original set up. However same thing happened. Amps powered on for a sec and went off.
Since you don’t have an ignition connect it to the battery ..for testing but it will need to be a toggle switch put in to turn it on and off ..it can be a small remote size wire because the ignition wires only activate internal relaysFYI on this set up I have the 12v ignition not connected to anything. That's where I'm confused. Should that be connected to something?
I'll get a switch then. I'll follow your instructions and will come back to let you know the results. Thanks!Since you don’t have an ignition connect it to the battery ..for testing but it will need to be a toggle switch put in to turn it on and off ..it can be a small remote size wire because the ignition wires only activate internal relays
Hopefully that will get you goingI'll get a switch then. I'll follow your instructions and will come back to let you know the results. Thanks!
Blue remote wire wasn't connected when testing as it was connected to sub amp when I had system wired up . I only set up Bluetooth amp for testing so blue remote wire wasn't connected to anything.Just to be clear because I'm confused by something you said...you do have the remote wire hooked up to the amp you're testing right?
