Is wiring the prob?.....
NE14MX
Finish the Drill
Ok I was trying a new setup in my car over the weekend. I was trying a new Arc KAR-900.1 and an Alumapro Alchemy SQ version. It is a DVC 4 ohm sub. I was wanting a 2 ohm load on the amp. There are 2 sets of speaker outputs on that amp. I just used one set to run to the box terminals. From the box terminals, I ran one wire from positive and one wire from negative to one pos and neg post respectively on one of the VC's on the speaker. Then I ran a wire from the pos post on one VC to teh pos post on teh second VC and did the same thing with the neg. Like this:
http://www.jbl.com/car/support/SubwooferWiring/sub_wiring_diagram.aspx?type=1-4-2
It had almost no volume. sounded terrible. So did I do something wrong with teh speaker terminals at the amp? Any ideas?
Volume sounds very low. I turned the gain wide open. and I could hear it but just barely while sitting in the front seat. I turned the non fader setting wide open on the eclipse 8445 HU but still way low on volume.
What could be wrong with the box? The sub was barely moving. I was concerned about the speaker output terminals coming out of the amp since there are two sets and I'm using only one. The manual for that amp sucks bad. I wasn;t sure it that would have an effect.
Ok I think I made a dumbass mistake putting the new HU in. There are lyrics coming from the sub, Think I could have hooked up the RCA to the wrong pre-out?
ya that could have been also your amp may have the low pass setting up to much. try around 80-100hz
NE14MX
Finish the Drill
NE14MX
Georgia
NE14MX
