is this wired up like it should be?
306stang
just got the new amp in (merlin md1) for two re se10-d4's
first off, i thought the amp would have one set of terminals for the speakers
there are two (almost like it's a 2-channel)
subs are wired as so:
pos to one vc , neg to the other vc , jumpers going to the others
the subs are hooked to amp like i'm bridging a 2ch.
i want it wired/hooked up at a 1ohm load.
i honestly think that it sounded better when i had one speaker hooked up to a kicker 600.1
i haven't tuned anything but is my wiring correct???
if it is a mono amp and you are bridging those "channels" you are going to be in for a surprise and likely why your gear sounds like crap. Mono amps just give two sets of input terminals for wiring simplicity. is still one channel.
Edit: So no. you are not wired correctly.
I think he was referring to the output channel. IE mono amps have 2 + and 2 -
Both POS+ outputs and both NEG- outputs are connected in parallel inside the amp. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
im actually glad you posted that picture. not alot of people realize this, and this image could really help a few people on this site.
306stang
306stang
Atlanta, GA
loopkiller
