Is this setup possible?
Is there an amp that could run 4 channels and a sub? The 4 speakers are a pair of 220w 4" Sony XS-FB1030 (30w RMS) and a pair of 420w 6x9" Sony XS-GT6938F (50w RMS). The sub is a 1200w KICKER Comp RT 40TCWRT104 10" (650w RMS, 2Ohm DVC). My Sony MEX-N5100BT head-unit provides 55w x4 of power so would it be better to run the speakers from the 4 channels on that and then a single channel amp for the sub? An amp that I was wondering if it would be suitable is the 3000w Lanzar HTG558BT. Anyone who could give me advice/help or find a suitable amp/setup would be super helpful!
This would be your best bet:
JBL GTO-5EZ 5-Channel GTO Series Class AB/D Car Amplifer
You'll need to rewire the sub to 4 ohms though or you may blow the amp.
Did you already buy all the rest of the stuff? If not, don't buy it.
My budget is about $750 and most well known brands (Alpine, JL, Rockford Fosgate, FLi, Sony etc...) are accessible.
Since you're in Europe, I think you should look into lower lines of Focal, B2, Gladen, Eton, Rainbow.
Tthis is the dealer I use: extremeaudio.de
You should be able to put together a pretty decent setup, though I'd still go with that JBL amp for the 5ch.
Are you stuck with 4" in the front and 6x9 in the back? Will you be able to build a box and are you going to install everything yourself?
Yeah stuck with 4" in the front sadly and either 6x9's in the back or I could fit 6.5" instead. I could build an enclosure but it will have to be shallow depth since of severely limited boot space, but yes my Step Dad could fit it all himself, he did the same for my Sister in her car.
If you were in the lower 48 States..Id offer you a good deal on an Elemental Designs 9.5 with a bass knob..Deff wont ship that far out though.Other than that, may look at ARC,PPI,maybe even a budgeted MB...JBL is a nice amp.
This is roughly what it could be:
ETON POW100.2 10cm 2-Wege Compo - 2 Wege Compo Systeme - Lautsprecher 10 cm - Lautsprecher
Hertz Dieci DCX 165.3 16,5cm 2-Wege Koaxialsystem SET COAX 2Way 165mm 1 Paar/2Stück - 2 Wege Koax Lautsprecher - Lautsprecher 16,5 cm - Lautsprecher
Gladen RS 12 Slim 30cm Flach-Subwoofer - 12" / 30 cm - Woofer Chassis - Subwoofer
If you can get them there, look into PPI 900.5 or JBL GTO-5EZ
Arm3dT3ddyBear
Arm3dT3ddyBear
Newport, South Wales
fly_marlin
