Is this a good box?
I had an atrend b-box a couple of years ago that blew up off some re audio 15's. The piece of **** had no glue and was put together with thin wood flooring finish nails. I never even considered a prefab after that and you shouldn't too.
I got an atrend dual 15" box. They definitely used glue on mine and plenty of it. Though it doesn't appear as if nails were used. I think staples were used instead. Don't know if that's good or bad......
It was white glue. Apparently they also used it on the corners instead of liquid nail. Never had a problem with the box though. Pretty leak less to me.
I'm glad you enjoy your poorly made box. You said they used staples. Lol, wtf? The wood isn't even 3/4, it says 5/8 probably more like 1/2. If you take a rubber mallet to the edge it will lift right up. You keep beatin up the block in your ****** prefab and think you are the loudest on the street.
I'm building something else. The prefab is going to be sold. The walls were 3/4 but the front baffle was 1 inch. I don't know what kind of bootleg atrend box you have.......
Typhoon
Typhoon
Phoenix,Arizona
Ahmed Johnson
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
