is this a bad idea??
oldschooldan
ok so i at my local pawn shop and they have six yes 6 10 incn kicker cvr's the 2003 style.. i want to buy them if i can run them all off my jl audio 1000/1..i think they are duel 4 ohm subs so i think i can wire them down to 1.3 ohms does that sound right?..and will it be safe for the subs and the amp?
good idea or bad idea??
How much can you get them for?
if they're in good shape the price is awesome, you MIGHT be able to fit them (with proper airspace) without mods for a sealed box, probably have to make mods for a ported box
i dont think you have seen the in side of a 96 impla ss trunk..lol..but its in a huge ported box and it will fit.with the the subs firing up if i keep the box... ill still have room on the sides and the back of the trunk.the box is 4ft long 2 feet wide 12.5 deep it has 2 chambers 3 subs each camber the ports look to be 2.5 inch wide pvc tube two for each chamber they look to be around a foot or so long...but anyway i have a really good box builder he can make anything..and everything he makes sound awesome..will it be safe for the subs and amp??? i think i can wire them down to a 1.3 ohms..
Just one question, why would you wire down to 1.3Ω? The JL slash series has the same output from 1.5Ω-4Ω, you can wire 6 DVC 4Ω subs to 3Ω and avoid potential problems using that amp.
This^^^^ I'd much rather run higher impedence. Slash series amps do fantastic at 3 ohm nominal and will be much happier.
Buy them, build a GOOD box and they may do allright, if not you won't lose much when you throw them up on Craigslist.
i knew a guy who had 4 of them running off two 500rms amps in a cobalt and was hittin the high 140s to low 150s but his box was so big he had to take out his back seat. id buy em and sell two of em with that box and take that money to build a new box for 4 of em and wire those to 2 ohms on that jl amp
I have built several Impala's over the years. 6 10's is a bit of a waste in them, but they will fit...sort of. I wouldn't recommend it.
Your car though.
Your buddy had to be blowing smoke up your aas. 1k before box rise an cheap 10's don't get near 150's.
You need to learn the difference in SPL meters. Where in VA are you?
oldschooldan
oldschooldan
mpls mn
bgowdy
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
