is the re box calculator really this off?
jsluss17
or did i do something wrong?
either the torres or the re one are pretty rough,
if you really want to get into it, look into a combination win isd alpha and beta.
yeah i have winisd i just have no idea how to work it. the re one is the easiest one to use i'm just hoping i didn't build a box that i thought was tuned to 29 but really tuned to 43
You need to put in the # of common port walls in the torres calc. It comes with a tutorial that explains things pretty well.
yeah i figured that out after i took that screen shot i forgot what it came up with though. i just used the12volts port calculator though and it says i'm about right on the tuning though so i'm hoping it's right
12v is saying your tuned at 40,
your enclosure is 2.24 cubes before displacement, with the port you have your taking up .23, which puts you at 2 cubes before sub displacement.
with that port at 2 cubes you wind up tuned at 40 before sub displacement, your probably a bit higher than that after the subs are in.
jsluss17
jsluss17
Scottsdale, AZ
Buck
