is the audiopipe 3000d 1 ohm stable?
i looked on the audiopipe website and it says that the 3000d is 1 ohm stable and on other sites it says it's not......is it indeed 1 oh stable or not?!//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
It is rated to do 3000x1 at 2 ohms. It is basically two ap 1500's internally strapped.
Lowest I've actually seen someone running it daily was like 1.4 or 1.7
You should be fine if the load hover around 1.5 on the amp. However I've heard the AP3500.1 is the best sub as in terms of low ohm load and durability. Some guy on here
said his team mate ran his at.5 ohm daily. Just have the electric to back you up
if you run each sub on 1 channel you will get 750 to each sub
running bridged and wiring it dif you get 1500 it is not the amp u want for those subs. you need a 1 ohm stable amp man //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
then you can run 2 d1 subs at 1 ohm
You need GREAT electrical to run it at 1 ohm, and even then it might not like it and go into protect. You can go 1 ohm at each channel and hook it up to each VC and that will give you 950w @ 1 ohm per channel.
not good,huh? better than crapsonic,lol. a co that has taken great american made products and sent the work oversea's and quality dropped. i was a autotek nut back in the day til they went down...
norrizzle90
Cant lose with 22's
norrizzle90
detroit, MI
1ndatrunk
michigan born
    May 14, 2026
michigan born
    May 14, 2026
