Is plywood good.
is there a home depot whitin your area? if so they will for sure have it and it will cost you about $20. i live in a shitty little town with no more then 900 people and the crappy little 2-bit lumberyard here has 3/4" mdf.
This is for all the tech guys and may help with choosing:
Below are some typical values for the modulus of elasticity (in million pounds per square inch) and density (in pounds per cubic feet) for MDF, Oak, Pine and Fir Plywood.
Material
MOE
Density
MDF
0.53
48
Oak
1.55
38
Pine
1.3
29
Fir Plywood
1.2
33
The modulus of elasticity (MOE), also called Young's modulus, is the ratio of stress to strain, where stress is the force per unit area placed on the item and strain is the deformation caused by the stress. The MOE is therefore a measure of stiffness.
Q: Can I build speakers with {MDF | particle board | plywood | solid wood}?
A: You can build speakers with whatever you like ! However, MDF is often the material of choice. Its stiffness and density yield good accoustical damping properties. Particle board and plywood are cheaper and can still be used if cost is an issue. Plywood (especially if void free) can be used in the main baffle as a sandwich material to better hold fasteners. Plywood is also a good material for making braces inside speaker boxes. Solid wood (lumber) suffers from movement - the swelling and shrinking of wood due to environmental changes such as humidity - and is therefore not a good material for speaker enclosures. Lumber is also not as acoustically dead as MDF.
There are times however, when plywood, particle board and other common sheet goods are more than suitable for enclosures. Such possible uses include sound reinforcement, musical instrument cabinets, and PA systems.
this came from http://www.bscaust.com/THE%20MDF%20FAQ.htm //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
No there isnt..Its about 30 mins away..
This is for all the tech guys and may help with choosing:Below are some typical values for the modulus of elasticity (in million pounds per square inch) and density (in pounds per cubic feet) for MDF, Oak, Pine and Fir Plywood.
Material
MOE
Density
MDF
0.53
48
Oak
1.55
38
Pine
1.3
29
Fir Plywood
1.2
33
Thanks for that information
Material
MOE
Density
MDF
0.53
48
Oak
1.55
38
Pine
1.3
29
Fir Plywood
1.2
33
AMEN!! Now go get the MDF for the last time and close this thread already! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Looks like these Knu reducers are free shipping, you'll need a few! NAd possibly some of these too:
68
4K
Yea 28hz is the lower limit of what I shoot for because you stop hearing the sound below that and more just feel it. It also starts to tear things...
17
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
pd298
pd298
oklahoma
fo0manchu
    May 20, 2024
    May 20, 2024
