talon2nr7588
how can i raise the voltage on my battery? my kinetick 1800 only reads 12.79. how do some batteries stay at like 13-15 volts?
i already have two batts if i add another will it help keep more voltage like letting the car charge up to 15 volts or 15.5?big 3 yellow top
H/o alt
/thread
yeah, um...pretty sure a yellowtop isnt gonna help that much if hes already got an HC1800.big 3 yellow top
H/o alt
/thread
what is the voltage on the other battery? are they connected all the time?
If you have a second battery and you have the big 3 and a H/O alt that kicks 240 amps then I would say that there is another issue. What is your Voltage across both the batteries with the stereo off and the car running. If they are just over 13 or less then you are not having voltage dip and nothing is going to help you. However If I were you I would call the company that makes your Alt and ask them to hook up an external voltage regulator. This will allow the alt to charge at higher voltage let's say around 15.5V instead of the normal 14.7V. This will intern increase your voltage across the first and second battery. Adding more batteries only helps you a little and will actually cause your alt to work harder and may actually cause a lower reading because of this. More batteries is not the issue. I would also think about increasing the size of the wire for the big 3 to maybe another run of 1/0 awg or maybe 2/0 awg. This will help charge the batts faster, resulting in less voltage dip. The readings you are getting are actually not that bad. What battery do you have under the hood, if it is a stock battery upgrade it to the same as the HC 1800 are at least the biggest one you can find. This will also help.
