Is my alternator taking a crap?
Hintzyboy
Sparks mean its working!
Hey guys. I was driving down the road Sunday night, and an indicator light comes on saying something is messed up with my charging system. My voltage dropped from ~14 volts to ~12 volts. For about 25 miles, it held a steady 12 volt reading, but then it dropped to 9/10 volts as I was driving home last night. Do you guys think it's my alternator, or is it something else? Maybe a voltage regulator? Is there any way I can check this without pulling a bunch of parts out of the engine bay?
Please respond if you have any idea what's going on. I need to get this fixed ASAP.
Thanks guys,
Aaron
youll know when it stops charging your car... But it sounds like the alternator starting to die, it might last another month or two with shoddy performance, but i would take action before it strands you.
Yeah, I talked to my car guy and just went and picked up a re-built one. About $130 after I get the core charge back. I also found out that the voltage regulator is part of the alternator unit (I have a very limited knowledge of this kind of stuff). But I think that is what was going bad. Because my gauges showed 9/10 volts when I last turned off the truck, but I pulled the battery to charge it before I install the new alt, and it's pretty much fully charged (DMM read between 11.9 and 12.1 volts).
IDK, but I have a new alty now and should have it installed by tomorrow or thursday.
Hintzyboy
Hintzyboy
Baraboo, WI
Hintzyboy
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
