Is my alternator powerful enough...
jb2
ny
i got a dodge stratus 04 and im putting 2 1500 watt amps into the car to power my 2 subs but does my car have enough to power both? if not can you please explain what i need to get to make it so it does
thanks im a newb to this kind of stuff
HE DRIVES A DODGE STRATUS!!!!
Can you do 100 push ups in 20 seconds?
But like they said, if you're doing that kinda power, do the big 3 and add a battery in the back and make sure the one up front is up to par too.
For 3k watts he is going to need a High output alt as well
If you think it takes 400A worth of alts and 5 batteries to handle 3k you're retarded.
At idle he'd get about 200 amps, pumpin a true 3000 watts @ idle will draw about180 amps....
Ad in A/C and vehicle ignition = 30 more amps so now at idle we are up to 210 amps
Get up to 1200 rpm then most likely he would see 300 amps which will keep the batts charged up from any stop and go traffic.....
Now if there are no stop lights and you only drive the freeway then no that much amperage is not needed to keep a steady voltage...
And Notice I said "STEADY VOLTAGE" meaning not dropping to any lower than
13V as in 13-14V like I posted...
Now if dropping to 11 volts is ok than 1 extra battery and a 150 amp alt will work.
I had a 90 amp with the Big3 and 1200 rms and my voltage would drop to 11.5 at idle and down to 12.8 @ 2000 rpm when hitting bass notes
So with my ghetto math 2 1/2 times the power = 2 1/2 times the alt which = 245 and thats to get a voltage drop like I did, which you dont want...
Maybe a little over kill but to keep a true steady voltage and charge everything run everything, it's not unreasonable
jb2
jb2
ny
only126db
