Is my 2v hu holding my system back?
i have that amp brz 1200 and i didnt really care for it now it sits in the closet! i upgraded to a kicker zx1000 and noticed a difference!
food for thought! but also gains could be off
found out what was wrong , i didn't have my speakers wired for 1 ohm , i did inside the box but used both of the + and both of the - on the amp , what ohm load was I running?
That's only a single channel on that amp. Those positive and negative speaker terminals are internally bridged. What you said kinda makes no sense. Explain it better, or post pics.
i have that amp brz 1200 and i didnt really care for it now it sits in the closet! i upgraded to a kicker zx1000 and noticed a difference!food for thought! but also gains could be off
The difference was in the settings not the amps. The Kicker is probably a more reliable amp though.
I had the + and - from one side on the box going to the + and - to the amp , and the side side of the box doing the same , so the + and - from the box never touched, so i twisted both + wires together and put it in the + , and did the same with the neg
So what was each sub wired to?
blimpthepimp
blimpthepimp
spring hill
gckless
