****it, you gave me the wrong answer!! ha ha i guess ill try again with the mat.haha you NEED the matting if it will be enclosing a speaker. I dont even think you can cal lit fiberglassing if you dont use fiberglass, it would just be resining... or something. Although it seems hard, you will probably get flexing with just resin. Trust me, slow down, take you time, and USE THE MAT!!!
i hope i got some spray adhesive...I'll give you a "cheating" way to do it, may not be the best way, but I've done it in the past and it has not sacraficed any strength...
The technique:
Before each new layer of glass (after the one before is completely dry), spray down spray adhesive (3M brand works good) on the entire thing, wait for it to tack up, then cut pieces of mat and lay them on it, using more glue for overlaps. Get the entire area covered and stuck, then apply resin and saturate the mat. This technique will keep the mat in place as you apply the resin, it works well.
Never tried those, but it seems to me they would be a pain to work with and not give as good of results. Personally I'd only use spray glue.nope, dont have any. will spray paint or super glue work?
or hot glue gun?
You wont be able to cover them, maybe add a few layers INSIDE the kicks, not on the outside. It will look like ***. But it seems like you dont really care anyways since you seem to like to cut corners on projects.ok screw it, im gonna use it anyways. 1 last thing...
y is it bad to put fatmat over fiberglass?
nope, all you need it for is to hold the mat in place while you resin, its not meant to ever provide strength in the final producti found some spray glue, but my mom says it never fully dries (just stays tacky). is that a problem?
no need to be so mean. i dont cut corners, i just dont know what to do. i was just asking if the matting was necessary.You wont be able to cover them, maybe add a few layers INSIDE the kicks, not on the outside. It will look like ***. But it seems like you dont really care anyways since you seem to like to cut corners on projects.
