Iraggi Alt doesn't put out at idle?
kentb
i got a new 240 amp amputator series that is supposed to do 165 amps on idle.
my voltage drops down(mid 13v idle) worse at idle compared to my stock alt(130 amps)(high 14v idle).
my ex only does 600 at idle.
do you guys know how many rpms the idle rating on the iraggi is?
both alt does more or less 15v @ 1.2k+ rpm
im using MLA module btw.
only kovemaster would laugh. i love your sense of humor man, dont know why everybody is always hatin on the brothas
cause they are haters. it dont bother me , since im going for a job in law enforcement so i got to get used to people hating me! but yeah im not one hundread % sure but i think i read that its out put at 1500 rpm
what job? im thinkin of going into I.C.E or maybe just be a cop.
This is a common issue with HO alts. They require a higher internal (within the alt) RPM than a stock before they can start giving power to your system. I'd contact Iraggi about replacing the current pulley on your HO alt with a smaller one to give the alt a higher internal RPM. Hopefully he can make one small enough to run at your car's idle RPM.
If not, another option to look at is getting the smallest pulley you can and then increase your car's idle to the point where the alt will kick on. If you don't sit in traffic much you won't see a big difference in your MPG.
x2
kentb
kentb
Las Vegas
audioarsonal
