This will make me look dumb
Black Truck 10
About to start my first install,
Im getting a sundown 100.4 amp, is it a problem that my front speakers are 4 oh and my rears are 2 ohm.
Will I need to do any special wiring like you do for subs or does that not work with door speakers?
Or would it be easier just to get a 2 ohm front speaker instead?
Fronts are Alpine spr-17s, Rears are Infinity Kappa 5x7's although I still might change these up.
I doubt my infinity kapp 5x7 will sound better than my Alpine spr-17s. But I do get your idea, so I might just try and find a good set of2 ohm components for the front, and sell my Alpine spr-17s speakers. I havent used them so I could just take them back to bestbuy.
should have got them on ebay, they're like 100 not 300, just letting you know sir...
Im an employee so I got them far below 100. haha. Im less worried about the back over powering them, I just wasnt sure if I wired doors in parallel or something (i didnt actually think people did this for components) then I could get my 2 ohm load or something like that. but then songs would send the amp a straight signal and the amp would be throwing that signal every which way because of the wiring.
2 ohm stereo = amp can run at 2 ohm as long as it's not bridged. bridged is 4 ohm stable. (bridged is using 2 chs as 1)
so you should be able to just wire the front up to 2 ch of the amp at 4 ohm, and the other 2 at 2 ohms. i dont see a problem at all.
your back isn't gonna overpower your front...
You might not even hear the back at all.
I run the sundown 100.4 off of a pair of ID 6.5s for the front and a pair of ID 6.5s in the rear.
The fronts get 100w per driver, the rear gets 150w per driver.
The rear is LP-d somewhere in the 500hz-700hz range and the fronts are HP-d around 400-500hz.
I did that just so i could get some of the rear fill audible while not sounding "off."
It sounds great but if i were to just full pass both front and rear, you cannot hear the rear whatsoever.
Black Truck 10
Black Truck 10
Houston, Tx
ultimate157
