iPod upgrade to 1.1.3
  • 1
redrocket
So, I was browsing the forums over at SoundDomain and noticed a thread that said if your iPod is updated to 1.1.3, it will no longer work with your head unit. I was wondering if anyone could check it out or say if this is true or not. I'm not hooking up my iPod to my computer again for a while I guess.
From SoundDomain:
We have discovered that upon upgrade to version 1.1.3 iPods that previously worked as "full control" will no longer function properly. This includes all 5th gen as well as 6th gen models. The only way for you to continue using your iPod is to downgrade to version 1.1.2
I would turn it to either flat, or better yet off if you have that option and use the head unit to control the eq.
I had to go from the headphone jack to an rca converter and plug into the back of my head unit. My old iPod won’t directly connect on any of my...
943
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you...
544
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
669
redrocket
redrocket
Lancaster, PA
redrocket
    May 24, 2024
    May 23, 2024
