Ipod issues with eclipse 726e
  • 1
gobes730
Hi i am in need of some help and i was wondering if anyone could help me out...
So i have my ipod touch connected to my eclipse head unit and it has been working great for the past few months and i have recently been running into problems with it. The problem is that the ipod plays music for about ten to twenty seconds and then the audio goes away, however the screen still shows the ipod song still playing. I have tried reconnecting the plug to the unit, making sure the usb and plug for the ipod are in working order. Also i have tried turning the ipod all the way off and plugging it back in but nothing better. It has become very irritating not being able to get the full use of my ipod in my vehicle. any help would be greatly appreciated!!
I would turn it to either flat, or better yet off if you have that option and use the head unit to control the eq.
I had to go from the headphone jack to an rca converter and plug into the back of my head unit. My old iPod won’t directly connect on any of my...
945
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
600
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
gobes730
gobes730
San Diego, CA
gobes730
    May 31, 2024
    May 24, 2024
