Inverting Subs
90accordman
Fresno, CA
someone please help me with the meaning of this. My thoguht is that you invert them in order to have more box space. If this is true is there any reason why nobody seems to do this with Kicker square woofers.
I know the question sounds noob but i just was wondering what would it hurt if i tryed to invert my subs just to see if the extra space makes a diff.
it has been done with kickers, but most people like the look of their cones. plus its not too hard to build a bigger box for more airspace.
If You invert Your woofer, the cone will over heat because there is NO backpressure on the pole piece. either that or You could have check the 100's of old posts here that pop up when You type "invert" into the search engine.
-Nick
-Nick
Whoa that's new to me. Someone else tell me that's valid/invalid?
-Nick
If you're gonna do that, atleast throw a "jk" in there or something... people WILL take you seriously and end up spreading stupid stuff they've read... as a guy with a high post count, people will take you seriously with what you say.
I have a lot of trunk lid rattle because my subs are firing directly at that area of the trunk.
If I invert the subs will the trunk still rattle the same no matter what way the cone is facing?
anyone tested this?
anyone tested this?
when u invert the su bs ur supposed to reverse the polarity of the sub OR if ur amp has a phase shift option use that.
as for the rattle, if the subs are facing and fireing towards the trunk then ur gonna get trunk rattle. to get more out of ur woofer and reduce trunk rattle u have to aim ur speakers forward, but the only trick is when you do that you have to create a baffle.
your best bet is to look up baffle and/or aiming subs forwards or something along the lines of haveing them fire towards the cabin to gather more details.
to sum that up what you need to do, if you have the sub fire towards the cabin you have to seal off the box to the trunk so that no air is able to move around the side/top/bottom of the box. essentially it's like makeing the front side of the box into a wall with a speaker fireing towards the cabin. you HAVE to do this in order to combat a cancelation of bass. if air can leak and move around to behind the box cancelation will occur. best cheap way to do this is build a box that will snuggly fit around thewalls of your trunk and use "great stuff" (sealent foam that hardens, like 4 bucks a big can at home depot or Lowes) to seal off the side......it all ride on the seal and the "wall" you create with the front of the box meeting the the rest of the car relativly perpendicular.
this is a creating a "baffle", also research about that on the forums (search botton IS VERY helpful.)
apparently you get better output fromt he woofer when you do this b ecause it save you the trouble of haveign the bass bounce off the trunk BACK into the cabin, this allows u to fire directly into the cabin.
correct me if i'm wrong guys.....
your wrong!!!!! :p
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
670
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
292
If they had an orange basket I would have to buy them.... Hmmmm Sell my 4 Xs and get 6 of those and do no-wall again with one more 4500..... :unsure:
4
390
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
654
Look at the Alpine Type S subs.
19
90accordman
90accordman
Fresno, CA
1aespinoza
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
