listen, i have heard a 15sx, also have an eD 15ae which is off a tc9 motor like the rlp so its somewhat similar, and have heard a fair share of type-r installs. The 15ae simply kills them all in terms of sq. the sx's and type-r's were pretty close sq wise from listening. in terms of linear output its no contest between the rlp and type r. they both will have similar sd's so at a given excursion will have roughly the same output. what does the type r have 18mm of xmax? so the type r at 18mm will have roughly 10% distortion as the rlp will only be at roughly 3/4 xmax therefore having well less than 10% distortion. this is not to say that the type-r cannot be louder than a rlp, because the type-r could have a higher xmech. however it is to say that the rlp has more linear output. It really can't be argued. If you do, you are arguing with the laws of physics not me...//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gifbtw: what experience or knowledge do you have to share. Or is it you that is talking out of your ***
edit: i'm done with this debate. back to internet brands..........
