internal bracing
  • 4
If you make it out of 3/4" MDF, and caulk and nail it well, you won't need too much bracing. I say just put L brackets in the corners, it should be fine.
2x2's work good but you gotta take in to count how much air space they will take up and add that to the total size of the box
other wise you will end up with not enough air space
good luck.
Ok thanks, i suspect that this one i uave may be faulty. I will purchase another one for the sake of it and see, thanks
5
358
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
778
Just the amplifiers use batteries to power it up. The HU are powered up by the car battery supplying 12 volts. The wiring harness...
6
Not sure what your options are for buying there then. Certainly NOT what we have here and I'd imagine between shipping at VAT tax you'd get...
5
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
942
choochooSS
Dont bufu a rabid Walrus
choochooSS
Kindaiwannapokeya
yelhsa
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
