Intermittent fault where no audio from head unit
  • 2
sad_muso
UK
Hi,
I recently purchased an RCN210, which I believe is basically a stock head unit used in China etc. Long story short, wiring it into my 2007 Passat Estate required connection to the the INFO CAN lines via the A/C control panel.
Installation notes
I've wired it up and I have backlight, bluetooth and power off with ignition so everything seems in order, but whenever I start the car it's random whether there will be any sound or not. When there is no sound everything else works fine.
I do have speaker issues - some of the wiring in the doors needs to be made good as it cuts down when opening/closing doors, but I don't think that this could cause the no sound issue.
The only other thing of note is that after the installation I have the airbag warning light, but I think this could just be down to amount of fiddling during the install and it needs resetting.
If anyone could shed any light on this that would be great.
UPDATE: Tried again this morning - first time turning ignition on no sound. Second time working fine. Parked up for 10 minutes and same thing again - first time nothing, second time fine.
Nobody else experienced intermittent no audio from a head unit?
Exactly the same thing here
Did you find the solution?
Have you checked if the RCA themselves plugged into the amp are showing voltage now with the radio off or volume all the way down? Check and make...
637
With the new info that factory amp is still connected, Coolhand20th's original assesment may be right. Radio may be causing the noise. I would...
14
It may be that they act like this because they are underpowered and the push to play them louder is causing the amp to clip the signal, which will...
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
629
sad_muso
sad_muso
UK
Costa
audiobaun
    May 19, 2024
    May 19, 2024
