Intermittent fault where no audio from head unit
sad_muso
Junior Member
UK
Hi,
I recently purchased an RCN210, which I believe is basically a stock head unit used in China etc. Long story short, wiring it into my 2007 Passat Estate required connection to the the INFO CAN lines via the A/C control panel.
Installation notes
I've wired it up and I have backlight, bluetooth and power off with ignition so everything seems in order, but whenever I start the car it's random whether there will be any sound or not. When there is no sound everything else works fine.
I do have speaker issues - some of the wiring in the doors needs to be made good as it cuts down when opening/closing doors, but I don't think that this could cause the no sound issue.
The only other thing of note is that after the installation I have the airbag warning light, but I think this could just be down to amount of fiddling during the install and it needs resetting.
If anyone could shed any light on this that would be great.
UPDATE: Tried again this morning - first time turning ignition on no sound. Second time working fine. Parked up for 10 minutes and same thing again - first time nothing, second time fine.
Nobody else experienced intermittent no audio from a head unit?
Exactly the same thing here
Did you find the solution?
sad_muso
Junior Member
sad_muso
UK
Costa
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
