Installing a battery isolator
yea on mine all that needed to be connected was the line from the first battery or alt whichever one you choose(battery is easier) to the isolator and another line running from the isolator to the 2nd battery and a wire for the ground on the isolator....mines is solenoid based so i didnt have to hook up a accessory connection it automatically switches on when the voltage increases over 13 volts...
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
133
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
benzmansl65amg
benzmansl65amg
Mobile AL
Twista89
    May 18, 2024
    May 18, 2024
