installed new HU now pwr locks dont work
Reit38
Total MindFawk
500
IA
i switched out a HU in my gf sisters car (95 grand am) and after i was done the power locks dont work with the button. it still auto locks when u put it in gear but u cant unlock it with the button u have to do it manually. any ideas, i thought maybe somehow a fuse went but i didnt know how it would from a radio install. thanks
Well there isn't a lot it could be. Either a wire got cut somehow or a fuse blew. Unless you just absolutely screwed up the wiring of the head unit beyond belief. Find a diagram of your car's wiring harness and see if there are even any door lock wires that you might encounter.
I have a GM as well with the same harness and I can tell you there is no way you should have encountered a door lock wire. Look here : http://www.installdr.com/Harnesses/GM-Wiring.pdf
^^ no i didnt know it wasnt workin till shes called earlier after she picked up the car i already said it was pry just a fuse but wanted to know if it could be somethin else instead
Reit38
Total MindFawk
Reit38
IA
Reit38
