Installed new fuse holder, problems arise
LoganSF
I had one of those cheap plastic agu fuse holders and used 100amp agu fuses. I had gone through two of them over a period of a year or so because the connection was ****** and it would short out and melt the fuse holder. So I just purchased an ANL fuse holder and a 100 amp ANL fuse. I installed everything fine, the connections were solid, however when I connected everything my capacitor began making this loud beep and read "1 volt" on the digital readout. Whenever I had disconnected my battery before to work on the car, the capacitor would do the same thing but would stop shortly after. Why is it not charging? It stops after a while once the car has turned off or has been running for a bit. Also, please do not give me a lecture on the use of a capacitor. I know they are more a detriment to the electrical system as a whole than a positive. I was kind of just influenced into buying one when i first invested in my system. I also don't feel like taking it out because I don't want to remove my backseat to access the grounds, and I've had the system in my car since January of 2009, and the electrical system is still running fine so... I don't know. Could anyone please offer some insight?
sounds like your cap has a cool digital readout on it! also sounds like it might be going bad not sure if they can but I also know your not charging it right so it might be? your supposed to use a resistor in line on the positive lead to charge it like a light bulb.
:: NANOPULSER.COM.SG ::
^^^Read this.
....and you're only reason for allowing it to continue being detrimental is that you don't feel like spending a couple hours taking it out? Regardless of how long it has lasted so far, your reasoning is flawed.
I understand that a capacitor is no good. Again, I don't feel like disassembling my back seat and rewiring my amplifier at this point in time if there is something easier I can do to remedy the situation.
That thing is a cancer on your electrical system. While it is constantly recharging after every voltage drop, it is robbing your amp of power. This will shorten the life of your amp. The "easy way" you are seeking is to remove it. The "hard way" would be to allow it to continue harming your gear, and end up having to spend money AND take everything out anyways.
i have an eclipse XA1200. I removed the cap and rewired everything to just my amp. Upon inspecting the capacitor is was leaking a brownish fluid out of the negative terminal and out of the LED screen. Where do i dispose of something like this? Also, my amp will not power on =[
If i were to remove the capacitor, what can I use to splice the two pieces of power wire from the battery together? 4 gauge btw.
You can use another fuse holder. Probably the safest way to do it.
While a capacitor does not harm your electrical system in any way, it certainly doesn't provide any benefits. And in this case, it's only creating problems.
LoganSF
LoganSF
Baltimore, MD
cdc351jeferson
