Installed my system, it wont work
my amp was lit up last nite
last time i checked today its not even lit up, im not sure if theres no power at all going to the amp or what
i have to get it looked at
its just so frustrating after spending all that time on it
test both variables, if i read correctly you tested the amp by hooking up a speaker and it didnt work, now go and try hooking the sub up to another amp (at low volume) and see if it works. Also try pushing lightly on the cone straight down and see if it moves freely
most companies are very strict when it comes to messing up a sub because of clipping. Unless it was defective but if you clipped it, then it doesnt matter. If i read right it might also be the amp. Try another amp, even if its one that does lower power as long as its something. See if that moves it a little.
just hooked it up on my home stereo, the sub that is
its not pounding but it is infact working, correctly too from what i can see
this makes me think theres problems with the amp for sure since its not lit up anymore when the car is started
any troubleshooting steps to check the amp, i bought a year warrenty on it too for 19.99$ it might have been well spent ill have to find out
Take the amp out and make some test cables for it so that you can set it on a fender or something convenient near the battery to test it. I went through some weirdness like this a few months ago and it turned out that the spot I chose for grounding was no good. I had alternator whine, amps would cut in & out while driving sometimes, sometimes the amps wouldn't power up, eben started smoking one of the amps. Changed my grounding location and everything cleared up. When you're troubleshooting, you want to deal with one component at a time and verify that it functions...sometimes it's best to remove it from the environment that it's in so that you can eliminate installation errors/glitches.
jeepskate, great info
im going to check all fuses when the car gets home then go on and check the grounding, im thinking the ground is the problem(hoping) i am also going to use my trusty test lite to see if my amps getting any power at all
thanks alot man
plr
i was just out at my car
there was power going to the amp thru the power wire, i had my trusty test light
for some reason the remote wire wasnt connected so i connected that
i just hooked my sub up without box to see if it would work
it played but didnt pound and didnt sound good at all
a min or so later my amps lite shut off any no power was going to the amp. does this mean the ground can be bad and the amp is shutting itself off?
im getting so pi**ed off!
i have it grounded to a type of metal wall, body of the car i guess behind the back seat
the amp thing is sorted out now, its grounded perfectly and for some reason i must have a cheap fuse set up because i had to tighter the PLASTIC ends together to get power.
anyway the amps fine i believe, as for the sub it must be busted, ill have to get it tested
i just hooked my sub up without box to see if it would workit played but didnt pound and didnt sound good at all
Why would you expect anything different? It's not going to 'pound' or sound good just sitting there with the back waves cancelling out the front output. Put it back in the box.
poorlilrich
poorlilrich
nova scotia canada
electronicsgeek
