Installed Cap and tuning question
Adding a cap wont likely cause much or any performance increase, but it shouldnt cause a noticeable decrease either, unless there is a problem with the wiring and/or connections. If it is causing a noticeable problem, current restriction via resistance is your culprit. That could be from too small of wire, poor connections, or simply from a cheap cap. I agree a second, rear mounted, batt would have been a better choice.
Even with the added resistance of a voltmeter, it should not create a perceivable degradation of audible output levels. It would simply add to the argument that the cap isn't helping to any sizable degree, if at all.
Jimmaaay
Greek Man
Jimmaaay
Concord, CA
audioholic
Mike Mccabe
