install like this.....
could someone tell me what all i would i would need to do to pull of a sub install like the one pictured below except using 2, 12"s whereas the subs would be firing upward out of the trunk cover of my eclipse and still sound good?
could you give a better explanation of how to go about doing it and what materials i would need cuz i have no clue?
well its simply making a box to form whatever shape below the hatch, then u just cut a big baffle with a single peice of wood... just make sure the baffle fits the shape perfect.. and then u screw the baffle down, along with the sub.
edit- look at my sounddomain page 4, and look at the first picture.. all u would do is make a box in the lower wheel well and then cut a hole for the sub... carpet and its a clean setup..
o my bad, but click on "System Installation and Fiberglass Help" (fiberglass section) and go to fiberglass links.. all those links will help u understand, but understanding is nothing like working with the **** stuff..
Originally posted by mgaidica creativity... some decent wood workin skills.. that install is clean as ever but appears to be very simplistic.
You forgot one thing. Lots of sanding. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
dynasty36d
dynasty36d
Md
MikeofTulsa
