Inexpereinced and need advice/help
nickexpy
Here's the deal -- I need a sub, I have been reading the posts for the past 2 weeks and looking at almost every subwoofer that has been mentioned and I cannot settle on 1.
I have a Alpine M350 amp, 350wRms @ 2 ohms. I'm looking to run 1 sub so it has to be dual 4 ohm and I want to have a daily driver sub, one that can function in all situations with all music genre's. Most likely slot ported box but sealed is not out of the question. It is a expeditions and I want to maintain use of the 3rd row.
1st -- I'm getting confused with all the watts. When you are looking at a dual 4 ohm sub and it says 300 wRms, does this mean per voice coil or 150 for each voice coil?
2nd -- I'm trying to keep cost down in an effort to save my marriage. I've already rewired the truck, installed new HU, 2 sets of components, and have a Alpine V12 4-channel running the highs and mids. I've been trying to look at under $100 dollars. Obviously some on the list are used and/or on Ebay.
Here is a list of subs I have been looking at and please interject any you think of that would work better or help me decide. Mostly I've been looking at 12 inch but if it was a good option in 10, I wouldn't be totally opposed. They are not listed in any specific order:
Diamond D1
Diamond D3
JL w3
RE Rex
RE Sr
RE RE12
Alphasonic PSW212
Memphis PR12D4
DLS W712
I cannot pull the trigger, hopefully, thats were you guys come in. Thx in advance.
1st - 300RMS means 150 per voice coil
2nd- I dont know too much about the other subs listed, but from owning them I can say the Memphis PR12D4 is a pretty decent entry level sub. Def. my choice when it comes to money. They are Dual 4 ohm so you can wire them parrallel to 2 ohms, RMS is 250W and 500W Max so your current amp should be fine.
Hope that helps a little, Chris
you'd be happy with any one of those, except maybe the alphasonic and dls. the box is going to make a much bigger difference than the actual sub you get from that list. i would personally go with either the diamond or RE in 2 cubish ft. tuned to 35ish hz. but the JL and memphis would be good too. box size would probably drop a little with the JL. not sure about the memphis.
nickexpy
nickexpy
St. Louis
luv2shrOOm
