jordon
Jw if anybody knew a cheap way to seal up your doors for some door speakers. Also anyone know where to get cheap mlv(mass loaded vinyl) for my doors. I don't hear much road noise now so it doesn't have to be the best stuff.
yes and they work great, the deadener has been very good, its has gotten to about 110+ degrees this summer and no issues with it falling off, it seems pretty thick and sticks very well, as for the mlv that works great too but read through the thread u linkedHave you used these? And how did they work? I've been wanting to do some sound deadening and noise canceling myselft. Also, awesome build here: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html. Dude is local, I still need to check out his build.
Did you use one roll one each door?yes and they work great, the deadener has been very good, its has gotten to about 110+ degrees this summer and no issues with it falling off, it seems pretty thick and sticks very well, as for the mlv that works great too but read through the thread u linked
I've used aluminum sheet metal (stuff is crazy sharp, use tin snips and thick gloves) - cut pieces bit bigger than the access holes they'd be covering. Slap some of that CLD tile onto it and use closed cell foam weatherstripping adhesive around the edges to decouple it from the door (Frost King is one brand, get it at the hardware store for a couple bucks a roll). Use self-tapping sheet metal screws to secure it (obviously make sure you're not drilling into or obstructing the window). Aluminum tape is also very handy.Dang alright thanks sounds good. Just need to figure out how to seal them up now.
