scolvin
Looking for 6.5 speakers that will work well with a Kenwood Excelon KDC-X491. Looking to spend $50 to $100 per pair.
Thnx for your input
Thnx for your input
Interesting. It's actually cheaper to order them from millionbuy.com directly as oposed to their eBay store.If you can do a component set, Almani PCS65C (PCS-65C) are the best speakers I've ever seen for the price... they were on ebay or millionbuy.com for about $50
Yep, they are the exact same speakers. One is the Pioneer standard line and one is the Premier line.Will TS-D161R work instead of TS-D601P?
Why certainly, but I will recommend you focus on the fronts first to bring the soundstage and imaging forward. Run it like that for a little while to get accustomed to it, and if you still want rears, then throw in some coaxs (like the REVs) powered off the HU.Can the Almani PCS65C also be mounted in the rear deck?
yep!Why certainly, but I will recommend you focus on the fronts first to bring the soundstage and imaging forward. Run it like that for a little while to get accustomed to it, and if you still want rears, then throw in some coaxs (like the REVs) powered off the HU.
If you run them full range, 50-70w rms each. High Pass them at 80Hz, a bit more. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifREVs it is. Looks like they will fit my 2001 Staurn SC2. Later if I add an Amp, how much power will they take?
