Incriminator Audio ?
Texas
In my search for my first system I think I have finally found what subwoofer I want to go with for my setup.
My question is:
Should I go with the Lethal Injection series ? its 189.00$ and the specs are:
600 Watt RMS Rated
DVC 2 ohm or 4 ohm
OR
The DeathRow series ? it is 319.00$ and the specs are:
• 1000 Watt RMS Rated
• DVC 1 ohm or 2 ohm
Also is there any difference in the Flatlyne series and the DeathRow?
I am only going to purchase one of these and install in the trunk of a 08 mustang.
Sealed or ported box, specs, and what amp I should use?
Would using this subwoofer require me to make the Big 3 upgrade?
go with the flatlynes on a 1500 mono
two dual 4s on a audiopipe 1500d would sound great
the other subs like ported boxes more and since its a prefab u are already limited on output
i have a 12" LI with a duel 2 running off of a MB Quart DSC 1500.1D amp, its a great sub and can handle more than 600 with no problem, i'm running 750watts daily but can crank it to 800 to show off a bit. as for an enclosure nick, one of the owners, suggested a 2.5ft3 box tuned at 32-34hz ported box. a 3ft3 ported box tuned to 33hz will in the end have a 2.5ft3 volume after port size and woofer displacement. my box is 14.5high, 28 wide, 17 deep, and the port 2" wide and a total of 21.5 long port.
I dont think a single 1500 mono can push two flatlynes...?
How strong is the single LI ? your setup sounds completley like what I Want.
Who would you reccomend I get a box of those exact specifications built by, who did yours?
you can go to youtube and there are several videos of single 12" LI subs. i have a wrangler with a single LI and it pounds hard, it rattles the window mirrors and i am able to clearly hear the sub with the top down and doors off on the highway doing 70.
i had a friend build my enclosure, he's a carpenter so he had all the tools to do the job. the size of the enclosure is up to you, but i went with what was recommended by one of the owners of the company
for 600...i can get you a sub and amp and a box... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif and im in oklahoma
All new? and tuned and installed? or just the supplies? cause if its just the supplies I can get it all here for about 500$ after shipping online.
Im at University of Arkansas.. I have alot of friends at OU though, Congrats on the win tonight !
i spent around $600 for everything, but i didn't have to pay to have an enclosure built i only paid for the 3/4 mdf. the sub was $200 delivered, the amp was $300 delivered and $100 for the 1/0 gauge wire kit
Thanks for the info.. I think I will go with this setup for sure, the videos just seal the deal for me!
thats what sold me on the sub. my amp puts out 1500watt rms at 1 ohm so the amp isn't working hard to power the sub, but i do plan on getting a DP from IA
no its used //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif and just the supplies....its not IA though its sundown and crossfire...ill be headed to dewitt soon if you know where that is...but i didnt know you were lookin for new lol. and thanks!
They all say they are in stock but they aren't. Just like my SSA Zcons and Evils were "in stock" but had a super long build time.
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
Looks good to me. Incriminator stuff looks high quality. The power numbers with subs and amp match well.
Texas
Texas
Dallas - Fayetteville
sundownz
    Jun 3, 2024
