Incriminator Audio needs your help!
Yeah, a ****in badass 5/6ch amp. With selectable bandpass on one set of channels...digital xovers on it? maybe?
Like...
Channels:
1&2: 50rms @4ohm (Highpassable 24dB/oct )
3&4: 100rms @4ohm... 200ish @2ohms... (bandpassable 24dB/oct)
5: Like 1200-1800rms @1ohm... subsunic... lowpass
w00t w00t w00t!!!
nG
id go 100rms 1&2, 75 rms 3&4. sence most peope will be useing front stage.
A 5 channel is a nice Idea but most of us are bass heads :p and mind you we use alot more power then a 5 channel on the subs. Now a good idea might be raffle off a few custom peices of future products say the 3.4 With some custom etching and a clear panel under the belly. Or podssibly dual 40.1's in a Double HS with a nice CNC machined logo's. I think chrome is over played how ever if i had to go chrome it would be black chrome. A 7" IA screen would be unique but dont think that would be best. Maybe raffle for a few items might be best so that we could havea few winners say like IA 3.4 , 20.1 , 40.1 and maybe a Warden and a DP all customized a bit with diff colors and extra etching so that everyone would know its a one of a kind .
I sure as hell would use it for midbass. As I'm sure NG was thinking also.
That would be one hell of an amp. Add bandpassable capability and //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
I'd be interested in the 5 channel is the 5th channel was like 600+ watts. front and rears in the 100w range are sufficient more is always better i guess //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
7 channel class a (or a/b) amp with a regulated powersupply on six channels(8, 4, and 2 ohm) that does:
ch1+2 - 50w
ch3+4 - 100w
ch5+6 - 150w
channel 7 (independant inputs with sum of channels 7+8): 300w@4ohm, 600w@2ohm
and onboard active crossover controls:
independant lp/hp crossover from 40-15k per channel pair
variable lpf/hpf slopes 12/18/24 db per channel pair
bandpass slopes for channels 3+4 and 5+6 (highpass only for 1+2 and lowpass only for 7+8)
AND make it less than 36" long
and if you really want to make it extrodinarly amazing:
external powersupply
one set of rca inputs with all crossover processing built into the amp
I'll take two!
Incriminator
Sub Designer
Incriminator
Alabama
KngOfThePkngLot
