INCREASE MID BASS! How to Sound Deaden Like a Pro
mklett33
MI
Hey guys! I see a lot of questions here about sound deadening and how to get the most bass out of your front speakers so I wanted to make something to help you guys out!
In order to get the most out of our front speakers we need to take some steps installing sound deadening, and do it properly. This video will show you how you can improve your mid bass by making your door into more of a cavity simulating a subwoofer enclosure. It also shows how you can use CLD tiles, Mass Loaded Vinyl, and Closed Cell Foam to properly deaden the entire door.
Check it out and let me know what you guys think!
Did it and what a massive difference. Highly recommended........
Totally huge difference, glad you were happy with your results, what did you use to block the hole?
---------- Post added at 11:51 PM ---------- Previous post was at 11:51 PM ----------
great video mark.
keep up the good work, love all your vids.
Glad to hear it! Did you see the one I did before with the foam ring around the speaker?
Sheet metal wrapped with roadkill and ccf strips to decouple it from the doorskin.
613
The difference in 96 to 98 db is going to net you about an 22% difference in output, all things considered equal. When it comes to 325 per channel...
809
gain set well below "Normal" and base boost is off completely
15
That was something I was going to try also to remove some of the gasjet from the front
mklett33
mklett33
MI
Ridgeline14
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
