In need of a true audio guru! HELP!
speaker wire is cheaper and easier to run than RCA cables...
I would run very small speaker wire ( maybe 18-22 guage? ) from the rear to the front to hook up the mx1 to the deck
then very short rca's from the MX to the amps and then 16G speaker wire from the amps back to the speakers...
and thats all there really is to it other than adjusting the settings...
if it is easier for you then just get 3 LOC converters and do it that way... ( if the deck has 3 sets of speaker outs...)
Okay so basically instead of running rca's down the side of the car. I would get small gauge wire to connect the mx-1 to the stock speaker harness? What would be easiest to connect them and tape them together and just run them down a side?
Anderson
Anderson
Mass
Anderson
