i'm very new to this....
  • 2
if you have a local radio shack store! you can get a FM amplifier for around 10 dollars and it will boost it by 10 db... if that's not enough... buy a car receiver that have around 3db boost on FM signal, so you can have better reception, if you are talking about the weak signal on the FM channel, I don't know about AM, neither I listen to it... but if you receiver weak signal on FM, then the signal booster will help you alot!
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
947
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
"I don't have any crossovers" You'll need one to filter out the low frequencies leading to your sub woofer. They'll produce no sound then...
14
cdearros
cdearros
Southport, NC
cdearros
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
