Im stumped. someone please help.
stay_high
Been having problems with my sub/amp for awhile now. Heres the scenerio. My sub started cutting in and out randomly one day and kept doing it more and more often. I checked everything and all was good. Tried different RCA's everything. Still no output. So i than rewired the sub to 4 ohm and ran the sub to my front stage amp and it worked. (so i figured the amp was old and just broke).
So i bought another amp (brand new) for my sub. Well i rewired the sub back to one ohm and hooked it up to my Brand New American Bass phd1600.1 and it works and sounds good... for about the 1 minute at a lower volume than it cuts out. The amp stays on (not it protect either) but just wont give any output. I than tried running different RCA's thinking it HAD to be that. Still nothing. So i started to think the SUB pre outs on the HU must be done. But no because when i hook up the sub pre outs to the rear channel of my front stage amp the sub wil play.. So i have absolutly NO idea what it could be. Someone please help.
Im using belva 0 gauge.... I had a pretty reputable shop install this stuff last year. The ground is still secure and all. If its a bad ground woudnt the amp be going into protect/blowing fuses or not stay on?
A bad ground will cause protect on certain amps or will cause a cut in power so the amp is running low power.
Check the ground or take a photo of the end of the ground so we have more info.
stay_high
stay_high
Florida
los33
