I'm putting together a complete system.
My opinion buy an American Bass ph1600md ($112.00) or a AB ph-2500MD. Look over at caco, Sundown is having a yard sale. Good subs cheap prices, or buy a good used sub. After I finally built a good box for my used RE SE 10 I love it. gets deep and loud (comparatively speaking) on 1000 watts. (ph2500md). Get knuconceptz 0 gauge wire CCA and you will be good to go.
Ok get the following
$203 Amazon.com : Precision Power P900.5 900-Watt Phantom Series Class D Full Range 5-Channel Amplifier : Vehicle Multi Channel Amplifiers : Car Electronics
$62 Amazon.com : Polk Audio DB651 6.5-Inch Coaxial Speakers : Vehicle Speakers : Car Electronics
$60 Sundown e12 from the yard sale
$100 custom ported from boomsday or cscstang, hell I'll build you one if your desperate
$32 Amazon.com : KnuKonceptz KCA Complete 4 Gauge Amp Installation Kit : Vehicle Amplifier Wire And Wiring Kits : Car Electronics
And add head unit of choice. Great beginner system, bridge the fronts of you want or add some rear fill later
Marine speakers? Is Sundown good? Theres a 12" sub for $90 that looks huge. This is really overwhelming lol.
I'm assuming I want a 2ohm sub instead of 4?
If you get a mono amp that is 1 ohm stable then you want a dual 2 ohm voice coil configuration, if your amp is a mono block that is 2 ohm stable get a dual 4 ohm configuration.
If I were you I would get one of the AB amps, and a e10, or e12 from caraudioclassifieds.org
SUBS----http://www.caraudioclassifieds.org/forum/sundown-audio/179231-sundown-yard-sale-4-6-15-a.html
AMP-----http://www.carstereogiant.com/American-Bass-PH1600MD-p/ph1600md.htm
AMP-----http://www.carstereogiant.com/American-Bass-PH2500MD-p/ph2500md.htm
Wire----http://www.knukonceptz.com/mobile-audio/power-wire/kca-kable/sp/kca-kable-10-ultra-fleks-red-cca-power-ground-cable/
ArmyNavyCopGuy
ArmyNavyCopGuy
long island ny
ArmyNavyCopGuy
