Im looking for a Farad Capacitor any suggestions
Buy a decent battery instead. Doesn't matter if the car is yours or not...
X2
If your running a power wire to the amp then what difference does it make if you put a battery back there too? Your already going to have to drill a hole for the power wire, might as well add the small battery in the back while your at it. Just run your amp off the rear battery.
ok, the alternator is a stock trail blazer alternator, and when the volume is not even on half way on, it drains the battery down to 11 volts I think (sorry im not at the truck right now but the needle goes half way between the middle and no power, if that helps), but my main concern is if I put a battery in the back can a stock alternator keep it charged or will I need to take it out once in a while to recharge the battery, or is there a charger that I could keep it hooked up to the back battery that will help it out (like a alternator, but mobile one)
and I don’t know if anyone has heard of this but I heard of a battery that recharges itself, I don’t know if that true but its suppose to be a small but very heavy battery, that somehow recharges itself), it don’t know if it is true or not
Your stock alt should be fine for your system, and will also work just fine if you add an extra battery. Adding an extra battery would be the same thing as just swapping your main battery for a really big one, in theory. I have a 01 Blazer and I'm pretty sure your alt s either the same or a little bigger than mine. I was running an Optima and a Kinetik HC2400 off my Stock alt for a long time and never had issues. I made sure the Big 3 was done before adding the 2nd battery.
And I've never heard of a battery that can recharge itself, I'm no electrical engineer but I don't think thats possible.
Energy(Joules) = Power(Watts) x Time(Seconds). The energy in a 1Farad capacitor = 0.5CV.V = 0.5x1x12x12= 72 Joules
The energy stored in a 1 farrad capacitor would power your amp at about 50 watts for under a second. An electrolytic capacitor IS NOT a battery.
For the sake of accuracy.
The cap should charge to 14-14.4v. Just say 14.4
1/2(14.4 x 14.4) = About 104J
The big BUT...
You have a battery there that won't let the system voltage drop below 12 or so, so any energy in the cap below 12v will never be used.
1/2(12x12) = 72J
104-72= 32J (watt-seconds)
At 500w the cap is useful for 6.5 hundredths of a sec at a time, and that's assuming it is a perfect storage device (no ESR), which it isn't.
I don't mean to hijack your thread but I have a question. Will a capacitor help in any way if I have a deep cycle battery? Reason I'm asking this is because I'm in the process of installing my first system myself, and I have a capacitor left from my last car and I want to know if I should install it or not. Around 1400 watts rms, stock battery, stock alternator. I will be upgrading the battery and alternator by the end of this year.
Edit: The capacitor doesn't sell for what used to, so it's not worthwhile trying to sell it. It's an eight year old digital lightning audio 1.0 cap.
rookanga
rookanga
flint, MI
SPL Blazer
