audioholic
not a moderator
Why would you feel the need to NOT have fuses? If fuses are causing you problems, you did something wrong.
Then your wire is not protected, and a fire is very possible if anything goes wrong.I never run fuses on an amp with on board fusing.
Normally Im fine to let disagreeing opinions go, but that is simply dangerous advice. What you called being scared, I call being smart. I dont care how good of an installer you are, nobody can guarantee they will never get into an accident. Auto manufacturers know what they are doing, yet every single circuit they installed in you car is fused.If you're scared of running without fuses.. you're doing it wrong. Use fuses if you doubt your ability to properly install an amplifier & think you're unable to tighten your input screw.
Oh I agree 100%. I never said it was a good idea. But it can be done right.. and done wrong. I'm saying his reasoning for being scared is retarded. "I'm scared it'll fall out & ground out".. wtf, do you not know how to tighten a screw? All I'm sayin'.Normally Im fine to let disagreeing opinions go, but that is simply dangerous advice. What you called being scared, I call being smart. I dont care how good of an installer you are, nobody can guarantee they will never get into an accident. Auto manufacturers know what they are doing, yet every single circuit they installed in you car is fused.
Your chair is teh awesomeness however.
Oh yeah? Well in millions of cases it wont lower your score! No, make that hundreds of millions! lol Obviously Im j/k, but I really have to wonder where you came up with your quantity of cases.actually in hundreds of cases fuses lower your score //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifthat isn't why I don't run them however. I don't run them because I have never felt the need to run them. If other people want to go a head and run them. If I install some one else system I will install fuses 100% of the time as well. Just don't stand on a soap box about me not running a fuse in my personal car. You know how to run wiring and use the proper sizing you don't need fuses to protect your wiring.
