im a no fuse virgin .
just a quick question, say you have a 200 amp alt and your running 2/0 weldng cable that is good for 450 amps and say you have an amp with a 250 amp fuse whats the point in running fuses then?
You fuse ONLY to PROTECT the wire, they make 450amp anl style similar fuses. You can simply make your own fuse block for it.
What happens if something cuts through the jacketing or the wire some way grounds itself out? Thats a big hunk of wire that will start on fire. Not to mention welding wire burns nicely.
but if you run you wire properly where there is nothing to cut it and secure it right then that shouldnt happen.
***** happens, if nothing were to ever accidentally happen this world would be coming to an end. That being said, Pro's who have been doing this for 30+ years have melted comp cars to the ground.
I remember seeing a pic on Termpro from a 170db vehicle being burnt to its frame because a few wires shorted. I'll see if I can find it
what happens when you get in a wreck and all of your power wires either break or rip off their ring terminals or whatever. Now you're in a wreck and your car is on fire. Not cool.
i run fuses, im just talkin hypothetically.
fuse it... keep a lil 15-30$ fire extinguisher in the car... has saved me once before //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
CAT MAN
Banned
CAT MAN
Roanoke,VA
audioholic
