if speakers dont fit exactly...
  • 6
Civic96Lx
Formally 92OldsTrefeo
am i loosing bass, do they have to be pretty sealed like a subwoofer would be... cuz i have some 6.5's in my doors and they dont go into my factory screw locations so i had to drill it in and it is a little tilted and not up against the back of the door...
Yes, you will lose a bit of midbass response as well as overall clarity will be reduced.
My recommendation would be to fab up a 3/4" MDF spacer that should allow the basket to clear to stock speaker cutout.
...so something that will go over the speaker location and allow it to flush mount it.. what should i use to seal it up?? silicon??
You shouldnt have to seal it with anything except a little non-hardening model clay around the edges of the "baffle" Another way to increase the midbass is to cover you doors in a dampening material.
I put 6.5" drivers in my front doors where the factocy location only allowed for a 4" speaker to reside.
Consequently I had to make a spacer to both allow it to sit flat against the door panel as well as allow for the backside of the driver to clear my window workings.
When I still used the OEM-sized speakers in the factory location ~
Before:
After I went with 6.5" components (though these are not the components currently installed)
After:
Closed cell foam or a MDF baffle. If they are behind the door and not flush you might get reflections with the door panel. You may or may not notice a sound difference.
If your doors don't look like this
or this (without acoustic fabric, ensolite in this case)
You need to fill those holes, the MDF baffle is really helpful as well. Just bolting up speakers is a sure way to make them sound bad.
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
116
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
76
38
910
310
Civic96Lx
Civic96Lx
Carmel, IN
///M5
    May 12, 2024
Brendon Jenness
    May 11, 2024
