are you wanting to use your backseat? i walled off my explorer (96) and after displacment im right around 10cf. i designed the box for 2 15 XXX but now its got 3 15s SX. i still have a lil room left if i wanted to go bigger but your not going to have a whole lot of room left for batteries and amps racks. i dont think youll be able 14cuft internal CRX box behind the back seats especially trying to fit amps and batteries...im trying to fit 3.5cubes per sub is my plan, went and looked at some explorers today so i just need to figure out when i want to do this
id have to tak everything out //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif but i could start fresh
just seems like it would, if not ill do 2 18s, because the back end looks alot bigger than my blazerare you wanting to use your backseat? i walled off my explorer (96) and after displacment im right around 10cf. i designed the box for 2 15 XXX but now its got 3 15s SX. i still have a lil room left if i wanted to go bigger but your not going to have a whole lot of room left for batteries and amps racks. i dont think youll be able 14cuft internal CRX box behind the back seats especially trying to fit amps and batteries...
yea me and jay know our explorers,we compete together all the time,but seriously i would go with 2 sx 18's,prolly around 12 cube should be good,u could put that back there with the subs firing up,port back.are you wanting to use your backseat? i walled off my explorer (96) and after displacment im right around 10cf. i designed the box for 2 15 XXX but now its got 3 15s SX. i still have a lil room left if i wanted to go bigger but your not going to have a whole lot of room left for batteries and amps racks. i dont think youll be able 14cuft internal CRX box behind the back seats especially trying to fit amps and batteries...
So is it P2P or Xmax (One-way linear?), kind of an oxymoron type statement.My suggestions :
Massive Audio CW 15
15 in. Subwoofer.
Dual 2.5 in. 4ohm, 4 layer voice coils with 54mm winding length on composite kapton / fiberglass former.
Conex spider, custom injected poly-mica cone with clear polymer to Illuminate Logo.
High current woven silver plated tinsel leads.
1”tall rolled Santoprene surround for MASSIVE excursion.
Removable gasket allows Onsite Re-Coning.
40mm. Peak to peak X-Max.
Dual Stacked 150 oz. Magnets, label plate with chrome finish.
Competition grade cast aluminum basket.
Molded ABS high ventilation label plate with chrome finish.
600w RMS / 1200 Max.
New platinum plated 5 way binding post with push-in terminals accommodates 8 gauge wires.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif I dunno man, take 40 mm and divide it by 2 and you get your xmax... didnt seem misleading to me //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gifSo is it P2P or Xmax (One-way linear?), kind of an oxymoron type statement.
nG
