Idea for boat install...
agarabaghi
It's been a while since ive messed around with mobile audio so Im just trying to get some suggestions for powering my system in the boat.
So i have sketched up a basic layout of what I want... and i have a couple questions...
Id like a way to lower the towerspeakers (hooked up to the cadence a7hc) with out lowering the inside speakers. Would I need an external eq or is this something the headunit might be able to handle.
Also, Im guessing if i was to add a subwoofer i would need a 3 amp, as the Cadence A7HC is a mono amp powering the tower speakers
I plan on running 2 batteries with a perco boat switch and solenoid for charging off the boat alternator.
Here are the specs for each part:
Clarion Headunit CMD4A
Specs i noticed:
- 2-Band Parametric Equalizer
- 2-Channel AUX Input with Input Level Control
JL Audio M770-CCS-CG-WH
Specs:
- Powered from the Cadence SQA-4100 AMP
- 100 w/rms
Specs:
- 100 x 4 rms @ 4 ohms to power the JL speakers
Cadence A7 HC
Specs:
Mono Block, 500W RMS x 1 @ 4 ohm, 800W x 1 @ 2 ohm, 1200W x 1 @ 1 ohm
500x1 @ 4ohms to power wet sounds speakers
Wet Sounds Pro 485
Specs:
300 w/ rms @ 4 ohm
600 w/ peak @ 4 ohm
Will power off Cadence A7HC
Just the output, basically what happens is everyone is listening to the music and the ride is listening to the music and as the boats is moving its fine, but when you stop to pick up the rider the tower speakers are usually WAY too loud, so instead of lowering all the speakers, id like to just lower the output
Problem is you cant get to the fader unless you get to the glove box, which is opposite from the driver. I though about putting a bass knob on the cadence, wouldnt that act similar to turning the gain down?
so maybe instead of an EQ ill just wire the basse knob under the dash and turn it down when the boat is idling...
I wonder how the tower speakers, which have a horn tweeter, and 2 mid bass drivers are going to sound power off the Cadence A7 HC?
Yea, i guess the A7HC will remain in the car and I will be looking at stereo amp to power the tower speakers. I hoping to get away with having to buy another amp as these tower speakers are insanely over priced. $900 for the one i listed.
Can someone recommend a good stereo amp that will put out about 300 - 400 rms for this speakers.
I was looking at purchasing this Cadence marine amp, and notice it says Bridged 2 x 300, im guessing peak (since the other numbers say rms). Could i then hook up both channels to the 1 terminal on the Wet Sounds Tower speaker and get approx 600w / 300w rms to them?
SQA-4100
4 CHANNEL STEREO POWER AMPLIFIER
Stainless Steel, rust proof terminals and connections.
Coated PCB and sealed with rubber gaskets.
Marine Grade components, for use in fresh or saltwater environments.
4 ohm RMS power: 4 x 100 Watts
2 ohm RMS power: 4 x 150 Watts
4 ohm Bridged power: 2 x 300 Watts
Frequency Response: 20Hz - 30KHz
S/N Ratio: >65dB
Damping Factor: >200@ 100Hz
Minimum THD:
Full adjustable 12dB Crossover.
Bass Boost Equalization Control.
Large gauge connection terminals.
Input Voltage: 150mV - 5 Volts
Dimensions: 8"(W) x 10.75"(L) x 2.4" (H)
2 Year Warranty
agarabaghi
agarabaghi
Orlando, FL
agarabaghi
