Ok so IB basically like a sealed box just has an infinite (or as close to infinite as you can make it) amount of internal volume. Would making a sealed box larger than recommended make it more like an IB setup. Would an overly large box pose any problems other than reduced power handling and increased risk of bottoming out. I am mainly wanting to know if it will change the linearity of the frequency response in a negative way.
Some people claim IB produce the best sq....if so wouldn't the best sealed enclosure be the biggest one you could fit. Assuming you are using a subwoofer that can be used in an IB setup
When I say sq I am not talking about of the entire system only of the notes produced by the subwoofer so 20-80 ish hz
