IA DP 15 vs FI SP4 15???
hook up the Sp4. Your box is just about optimal for it (4.25 net) although it's tuned a little high imo.
I'd wager to say the Sp4 just might be better than the DP in the box you have currently, although the DP isn't a slouch either. Sold mine to Souldrop and wish I hadn't. He posted a real good review about it
The DP has better botom end but the DP is a hell of alot more efficient about 50 hz. the DP needs a larger box than the SP(light mms stiffer suspension low QE) the DP will whale with 2500 in that box..
If I was you I'd hook up the sp4 and see how it sounds. U might really like it. What do u have to lose? Nothing
I have it hooked up now. Thing doesn't even move at all even at 28-30 hz full tilt.... It doesn't sound bad, but the HD was louder by a bit to the ear
It's hooked up now and my Hd15 was louder. The sp4 doesn't even move full tilt. Lol... It's a beast lol
Your woofer will move the least at tunning. So is your box tuned 28-30hz? Because if your tuned to 36hz that woofer should be moving like crazy under tunning at 28hz
It doesn't move that much 28-30hz... And it's not that loud there... More just Rumble. It's seems due to power my hd15 had more authority
what version DP is it?
they are all good but a v1 may be a bit worn out by now.
personally i would get the DP provided its in good condition, and i would get a larger amp, you can always turn down the gain and that sub will take a good bit of abuse
what version DP is it?they are all good but a v1 may be a bit worn out by now.
It's the newest model. With the star motor or whatever... I
bgowdy
Heroes are remembered, but legends never die
bgowdy
Campbellsville, Ky
Massive spl
    May 16, 2024
    May 16, 2024
