Just to clear that up, yeah it is a mono amp with 2 positive and negative terminals. They are connected internally. You can just use one set of the + and - and be fine.So this is just a 1 channel amp with 4 outputs?
I have an alt without the big 3, I took that out bc I am getting a new car. But I Wanted a temp setup to drive to texas. I have 2/0 welding wire to back batt and I have 2 runs a piece in 0 gauge to posi and negi
edit- so if I hook up the subs at .5 it will make the amp see .25? I dont understand
Hell I thought they could do .35 burp and .5 daily.....Just to clear that up, yeah it is a mono amp with 2 positive and negative terminals. They are connected internally. You can just use one set of the + and - and be fine.
Also, I dont think with a 250amp alt and a NSB in the back that the amp would have fried just because you didnt have the big 3 done. Of course I could be mistaken but it just seems unlikely. It could have been from too low of a load on the amp.
This is my TENTH 9515 WHEN THE **** WILL I LEARN!!!!!!!!!#1. Do not ground a 2nd battery to a seat belt bolt. Use the actual frame or run to front battery#2 Do not run that much current without the big three
#3 That amp has the ability to draw a lot more current than 450 amps at .5 ohm. For daily I wouldnt take it below one ohm.
Take care of your equipment and it will take care of you. If this is your first install you may have started with a little smaller set-up as not to lose so much at once.
sucks dude but you live and learn.
So why would they put 4 channels when you can only use two
More importantly change the back battery ground.This is my TENTH 9515 WHEN THE **** WILL I LEARN!!!!!!!!!
I guess this is the wrong amp I needed then, I have 2 dual 2 subs...
I guess the big 3 was what it was
This is the shit that confused me..The positives are bridged together and so are the negatives. You can use both or just one. But if you use both and have each sub paralleled to one ohm the amp will see .5 since its mono.
I would series each voice coil on the sub (4ohms) than hook each sub up to the amp.
