I want it louder!!
no problem .like i said i still have my old box thats a inside below the window line for 2 12's if you wanna go that way .also if you want to do a blow thru ,the 15's is the biggest sub that will fit there unless you use a camper shell
i had 2 alts ,a 200 amp and 175 amp adjustable voltage they were 550 alone ,then i had 200 ft of wire at 175 per roll ,my box that has alot of time in it prolly 3-400 in that alone without the ports.then subs amps and batts.i can arrange for you to get some deks batts pretty cheap in ontario .i had 5k in my system easy .but i can be done for less ,if you know what to do and what to get
yea i here ya ,just get a bit at a time ,i can save you some money in some areas of the build ,but i can take care of all the equipment needed ,and i do mean all of it
Yes, I have a difference, but my difference is HUGE. The difference can be so big, as if I had a sound system in about 150-200 dolars (with wires...
41
9K
im not looking to seal off im trying to stay out of wall classes and plan on staying in trunk classes
15
What are some of the louder, while still sounding good, 6.5" sets out there? Been looking at some of these higher powered Sky High Car Audio sets...
My subs unload at full tilt @ 28 hz, They are in 3.69 cubes net tuned to 34 hz. 4 - 8's. Big box and big power.
<s10¢>
San Bernardino, Ca.
<s10¢>
    May 24, 2024
